College Football
Elwood
Man, there were some awesome games today.  Really close ones, and good upsets too.  :cheers:
5 Ranked teams upset by UNranked teams (Florida #5, Washington #12, Kaansas State #16, Colorado State #22, and Texas A&M #23.
1 upset in the ranking Penn State #21 over Wisconsin #15
5 of the top 10 barely won over unranked reams: Texas #2 (by 2), Oklahoma #3 (by 7), Ohio State #5 (by 11), Georgia #6 (by 2), and Tennessee #10 (by 3 in 6 OT).
FSU almost got beat Thursday, Clemson just lost it in the 4th Quarter.
The polls should be shook up very nicely on Monday.   :thumb:
What about them HOGS it really ticks me that they played well enough to take it to 6 OT'S.  The last 2 years they have played in the two longest games in college football.
The Razorbacks should've won that one.  2 missed FG's in regulation, and one in the 2nd OT.  They had it wrapped up in the 2nd OT.  TN fumbled and all they had to do was score, and they missed the kick.
Well, I am just happy Nebraska finally won a game, even though it was against a Division II team.  But hey it is a win :thumb:
On a side note, to my surprise, UNLV actually beat UNR today to keep the Fremont Cannon (it is a cannon that either Vegas or Reno has depending on who wins the yearly game)...
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
