Gm 6 Speed Transmission Problem
Hey,
I have a 2010 gmc Sierra with the 6 speed tranny. Since i bought this truck i have noticed that it shifted really hard. after experimenting with it i found that if i shift it into M while around 50km it says its in 5th gear and in 6th around 65km. I dont really understand the 6 speed tranny but this seems to high at that low of speed to me. Also when a give it throttle its like i have to slam the pedal down just to get the rpm to jump and some times it catches at an rpm around 4000 and will rev there for a couple seconds then bring its self down.
ANY SUGGESTIONS ? THANKS
it's designed to get to 6th gear as soon as possible for best fuel economy.. with the 3.08 gearing it's a dog and it can feel like a chug chug at lower speeds,
I have the 3.42 gearing and it is a little better, but i drove one with what I think was 3.73 gearing and it's a rocket in comparison to the 3.08s, but fuel economy suffers..
How many miles on your truck and have you brought it into service? There could be an issue :lol: Mine shifts awesome but I do have the 3.73 gears. :thumbs:
I have the 3.42 gearing with 9000 miles on it. I have mentioned it to the dealer and says thats normal for the 6 speed. But should it be in 5th 6th gear in the city going around 50km-65km ? it wont drop a into lower gears until i hit a lower speed under 50km.
Doesn't seem right to me, but I don't have the 3.42 gears. I'm sure others will offer up some.
i have a 6 speed 3.42 and i really don't know when it shifts most of the time unless i put my foot in it. Occasionally 1st to 2nd shifts a little hard.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
