Gmt900 Tsbs
I once saw a link for a whole list of TSBs posted on this forum somewhere but i cant find it again. Specifically im experiencing the infamous tick, but it is lasting longer than 1 minute. I can hear it only at idle and when im up against a building. I would like some paperwork when i go to the dealer. Thanks
