Ac Issues
adam.t.mazzara
AC won't cycle on when AC is turned on. Low side Pressure reads 30 when car is on, but when I jump the AC cycling switch the pressure reads about 10psi on the low side. Just low on refridgerent? Any suggestions?
Adam
If it's reading 30psi when the compressor is not running, & the air temperature is ABOVE 30°F, then you may be just low on refrigerant.
Don't keep running that compressor down to 10psi jumping it ... especially if it has a low charge. Bad things can happen.
I wish I lived in a place that required A/C this time of year. It was -10°F here in MA yesterday morning! :smash:
yeah its in the 40's and 50's here, no real need for the AC just making sure for when I go down the mtn this weekend where its 85, so I guess I'll try to shoot a can or R134a in it. Thanks for your help. I feel your pain Im originally from Wisconsin
