Double Image In Drivers Side Auto-dim Mirror
old-chevy-dude
ever since I bought the Avalanche last October I have noticed a double image in the drivers side auto dim mirror.
it is most pronounced at night with headlights when auto dim is active, I get one greenish image and one white image.
I can also see it during the day, usually when a car is behind me with DRL's or headlights..
there is a very specific "wave" in the glass, in one spot that is causing this, the dealer techs say they can't see it and the mirror is fine.. anyone else experience this?
yeah, mine does it too- but not always. it has to be at the right angle with the car in the right spot. usually only at night- i wind up seeing 4 headlights instead of 2.
Mine does that also. I have told my service writer about it at least 4 times. Every time Im at my dealer I ask if there is a repair yet. GM calls it a ghost image. There is a bulletin about it that says its normal and there is no repair.
yeah, there is nothing normal about it, it's a defect in the mold of the glass.
there is a clear "wave" in the glass, and the double image is caused by the wave because the dimming layer and the reflective layer are separated..
I can clearly see the wave and I can feel it running my hand over it.. and I find it to be distracting and dangerous, the ghost image makes me believe there is something there when there isn't.
I feel your pain. Mine also has a wave in it. This is dated to 07, it is old but I bet it applies to newer models.This information applies to 2003-07 Cadillac Escalade, Chevrolet Avalanche, Silverado, Silverado Classic, Suburban, Tahoe, GMC Sierra, Sierra Classic, Yukon, Hummer H2 with RPO DL3 or DL7.
Some owners may comment that the driver's outside auto dimming mirror RPO DL3 or DL7 has double vision or a ghost image.
The auto dimming mirror uses a 3rd surface chrome glass (a mirror without auto dimming uses 1st surface chrome glass). The layers of the auto dimming mirror are:
- clear glass
- auto dimming fluid
- chrome surface glass.
Due to the auto dimming fluid being between the clear glass and the chrome surface glass, some customers may notice double vision or a ghost image, which is a normal characteristic. Replacing the mirror will not correct the concern.
- clear glass
yeah, well I have owned several vehicles with monchromatic auto-dim glass, and never had this issue.. GM needs to correct the problem not make excuses..
G.M. has had this problem for some years now (my 01 vette had the same thing) ! My advice is to ask to talk to the district factory rep for your dealer, the replacement glass is availible,, but expensive keep up the fight your not alone! hopefuly the disctrict rep can help!/Dave :thumbs::D
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
