'84 Gmc S15 Extended Cab Desperate Help
ok. i have a difficult situation. i need to know what size engine i can put into a 1984 gmc extended cab s15 pickup truck. my engine blew up a month ago and i am in desperate need of what engine to look for because i CANNOT find an engine the exact size and type. btw the truck is MANUAL transmission
For that year truck, you could look into a V8 swap for a decent price. Yes, it's more involved than putting in the same engine, but if you don't even know what you have in there, then why not start fresh with something you do know is in there?
if u dont want the v-8 swap, u should easily be able to find a 4.3l v-6 from a blazer or s10 pickup, there are thousands out there.
PS, u may need to find one with a trans now that i think about it, the 4.3 wasent offered in that year. sorry.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 716 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
