Corsa Tip Is On!
picked this up for free. Now i just need a dynomax VT muffler. sorry so dirty its been raining
just picked on the bumper end cap from dealer yesterday. Someone bumped it and dented it. going to pull off and powdercoat black
Dirty????????? I should take a pic of mine after driving to the mines the last week. It would make you vomit!!
Tip looks good BTW! Corsa tips are hard to beat.
I'll be honest when I saw your other thread about you getting a tip, I was like great he's gonna put that cheap ass tip on there? But now that I see it, I admit it does look pretty damn good.
This has got to be the longest, drawn-out exhaust saga in the history of truck moddin'.
If you're gonna take this much time deciding on doing it, you'll never end up with a pile of "mistakes" over in the corner, like the rest of us have.
Just KIDDING!!!!!! It looks good and you'll be happier when you get that muffler on.
Yea Im not a fan of chrome tips, or for that matter, any exiting exhaust pipes... I hate looking at factory exhaust pipes. I rather cut the pipes off at the muffler, but that tip look good on your truck.
Dirty, really? Come live in NW Indiana for awhile. :rolleyes: I'm on the edge of offing myself everytime I look at mine lately.
Tip looks great!
    Gkistler
    Gkistler
  • Who's Online   5 Members, 0 Anonymous, 791 Guests (See full list)
