nickvrebel Posted February 10, 2012 Posted February 10, 2012 all of your old remotes will need to be reprogrammed in at the same time as the new ones. read the manual on how to program remotes, each time a new remote is to be learned it clears all remotes and you must relearn all of them.
Slugworth Posted November 23, 2016 Posted November 23, 2016 You essentially just get new fobs, but the accessory kit that GM sell comes with both fobs and the special code that becomes associated with your truck allowing this feature to be turned on permanently and not turned off if the body control module is reflashed. p/n 17801236 from GMpartsdirect.com currently is 128.31 and you will pay less than an hundred buck for the dealer to program it. Call the dealer with that p/n and see if they can beat/match the price. Dam, there not $128.31 anymore!!!
Coby7 Posted November 23, 2016 Posted November 23, 2016 Nope around $230 now, and you can only use this kit if you have RPO code AP8, if you have AU3 you need a different kit. 1
Coby7 Posted November 23, 2016 Posted November 23, 2016 all of your old remotes will need to be reprogrammed in at the same time as the new ones. read the manual on how to program remotes, each time a new remote is to be learned it clears all remotes and you must relearn all of them. Not if the technician selects next available slot in the procedure when programming new FOBs.
Slugworth Posted November 23, 2016 Posted November 23, 2016 Nope around $230 now, and you can only use this kit if you have RPO code AP8, if you have AU3 you need a different kit. I do have the AP8 code. Looks like it would be close to $300 to get it working.
Coby7 Posted November 23, 2016 Posted November 23, 2016 Still cheaper than having a remote car starter installed and you never know what kind of hay wire job they're going to do. Depends how desperate you are to have a warm vehicle when you slip in. 1
Slugworth Posted November 23, 2016 Posted November 23, 2016 Still cheaper than having a remote car starter installed and you never know what kind of hay wire job they're going to do. Depends how desperate you are to have a warm vehicle when you slip in. I was thinking the same thing. Who knows what hack job they could do!!!
Slugworth Posted December 9, 2016 Posted December 9, 2016 Is this what I need?? http://www.ebay.com/itm/17801236-Sierra-Silverado-Acadia-Equinox-Avalanche-NEW-Remote-Start-Kit-OEM-GM-/281601438330?hash=item4190c0f27a:g:8M0AAOSwv0tU4lRN&vxp=mtr
Coby7 Posted December 9, 2016 Posted December 9, 2016 (edited) Yes if yours is 2007-2013. Just saw you have the year 2011 listed in your signature. Edited December 9, 2016 by Coby7 1
Slugworth Posted December 9, 2016 Posted December 9, 2016 Yes if yours is 2007-2013. Just saw you have the year 2011 listed in your signature. Yup mine is a 2011 with the AP8 code Thanks!!
Slugworth Posted December 14, 2016 Posted December 14, 2016 (edited) Dealer told me around $432!!! I assume that's with ordering the kit I need. Edited December 14, 2016 by Slugworth
Slugworth Posted December 14, 2016 Posted December 14, 2016 If I buy the kit for $211 that's the cheapest I can find it. They will charge me $157 to reprogram it all, but won't warranty anything. So for $60 more for the kit from them I'd get a warranty on the install.
0verWatch7121 Posted June 21, 2020 Posted June 21, 2020 Quote I have AP3 rpo code but the remote will open the rear glass, not start the truck(2007 Suburban 1500 4wd). Any suggestions on what to look for? Have new ECM and BCM. All code issues have been corrected and cleared. Any and all help is appreciated.
carnau Posted June 21, 2020 Posted June 21, 2020 13 minutes ago, 0verWatch7121 said: I have AP3 rpo code but the remote will open the rear glass, not start the truck(2007 Suburban 1500 4wd). Any suggestions on what to look for? Have new ECM and BCM. All code issues have been corrected and cleared. Any and all help is appreciated. I feel like you should have made a new post for this. Lol. The liftgate will open, just the glass will not pop? Is this correct?
0verWatch7121 Posted June 21, 2020 Posted June 21, 2020 Glass opens when I push the button to remote start the truck. truck doesn't start.
