285/60r20 Tires W/ 2" Rc?
wave032000
I am debating to put some larger tires on my truck. I have stock 20x8.5 OEM wheels and have the stock 275/55R30 wheels on now. I am wanting to put a 2" rough country level kit and was looking at upgrading my tire size to the 285/60R20 size. I imagine there will be a little bit of plastic that I will cut, but I am wondering if it will rub on the front fender? Will this tire fit?
Im not sure, but my 285/60/18's fit just fine when I had the daystar 2" leveling kit. Can't be for sure if you are going to use the factory wheels.
With tires for every inch you increase the rim size you decrease the aspect 5 and it is approx the same diameter so the kit is designed to fit 285/70/18 so 285/60/20 should be about the same diameter and will be the same width so it would work no problem at all.
They will rub for sure. If they do rub on the front of the liner it would probably be on the front inside of the d-side liner and you could just use some zip ties to pull it forward. That is a pretty good sized tire (33.46x11.22), so you may need some metal cut too.
  • 11 months later...
Looking at some Duratrac's of the same size, 285/60r20 on stock rims with a 2" RC level... Guys at Goodyear said they have installed this setup plenty, and it fits, no problem... You are saying it will rub? Would a 1.25" BL fix this, or is it too big even for that?
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
