Tread Wear
I think I have some seriously odd tread wear going on with my tires.  My front passenger tire is almost completely flat in the middle whereas the driver side fron tire is still good on tread.  I have checked the tire pressure over and over and it is set to the cold tire pressure reading on the door of the truck (the # escapes me right now).  Anyways, I was wondering if it has to do with my torsion bars at all because after getting it back from the dealership, one of the bars was cranked up really high and the other one was cranked down but they were really close in actual height from the ground.  Any ideas about this or should i take it to the dealership to take a look at?   ???  ???
I'd take it to the dealer.
Generally tread wear in the center of the tire means it is over inflated.  Since you say that both tires are inflated the same, then I would have to say it is an alignment problem on the right front.  I'm not saying that the tires aren't still over inflated, but they should wear the same...  In a lot of cases the cold tire pressure is the max. number and is too much air for a vehicle that isn't carrying a load.  For example: my HD calls for 80 psi cold.  I run 50-55 psi for everyday driving.  I know this is a good pressure to run because after I pull off a dirt road and run about 1/4 mile on pavement, the bottom of the tire is cleaned of all dust except for the very inner and outer edges (1/2" or less).
    • Yesterday we brought home a 6yr  old Havanese dog from a nearby SPCA.  We've had her for 24 hours and we are delighted with how well she is adjusting to her new home.  It  was a huge decision to adopt a dog at this stage in our lives but we believe we made the right choice!   it was reported that her first 6 years were ones of neglect.  I think she's already realizing her life is going to get a whole lot better...  so is ours!
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
