I have an 01 GMC, and I want to do the quad headlight mod. From what I have searched, it the links on here work for 03-07 trucks.
Does anyone know if the process is the same with the diodes? Or have you done it?
James
For the 99-02 models you just ground the yellow wires on the low beams.
What is the best route to do that? Any issues to worry about with heat, or the wiring itself?
Thanks for the quick responses.
James
I just used a t-tap and a piece of wire and a grounding terminal and grounded it to a bolt behind the light, never had a problem, heat will be less of an issue since the light is getting a direct ground now.
Hmmmm, will this make them be on all the time? I have the automatic sensor on the dash, and I only want the lights to be on at night when needed, and then of course stay on with the brights. How is that a different ground causes the lights to stay on? Does the high beams cut the ground on the low beams entirely to turn them off normally?
James
No, they won't stay on all the time, they'll only stay on when the headlights are on whether the brights are on or not. And yes, that's how the system works on these 99-02, it swaps grounds(between the hi and lo) when you hit high.
on an 07up the low beams stay on with the high beams so if you want them all on at once just turn your high beams on and be prepared to piss off a lot of people
Didn't know that Thanks!
    B07
    B07
  • Who's Online   1 Member, 1 Anonymous, 871 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
