Cleaning Leather Seats
What is a good way to get stuff out of the cracks and seams in leather seats? Mainly just where you sit. Stuff like crumbs, dirt and all that. I cannot seem to get it out with a vacuum or by wiping it out with cleaner. It's stuck in there good.
Are there any tricks or secrets to this? I was thinking something like a toothpick to scrape it out and then vacuum.
Have you tried a old tooth brush with a little bit of water w\ a little soap then wipe it off with a wet cloth and finish it off with a leather conditioner
take a paint brush and cut about half the bristles off. This should help loosen the debris without causing any harm as the bristles are still pretty soft.
    Policeoff01
    Policeoff01
  • Who's Online   3 Members, 0 Anonymous, 823 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
