Kodiac's Have Same Cab?
Would a 95-ish Kodiac or Topkick have the same cab (doors, seats, interior) as 95-ish silverado? They look the same, but I haven't been able to put one next to the other to compare exactly.
Long story short, a tree trimmer in the neighborhood needs some parts for his driver's side door, and I'm fairly certain that they use the same parts as the silverado's of the same year.
He needs the "catch" or "guide" for the door. The piece that holds the door in certain positions so that it doesn't just flop around when it's open.
James
No, the cab is different. The floor, firewall, and mount locations are different. The doors and glass are the same. Some '90-'02 Topkick/Kodiaks have a taller roof too.
