Costar Bluestar 2010 Module For Sale
FMinMI
Up for sale is a CoSTAR Bluestar 2010 bluetooth hands-free module that replaces your OnStar module and interfaces to your radio and built-in microphone. It is a neat device – plug and play; no wires to cut or splice, and you can reinstall the OnStar unit at a later date. Just two connectors to pop out and plug in. My unit has the latest firmware (with the new DSP programming that significantly improved performance) and the latest software (version 1028). I have had it for a year and is in perfect condition. Comes with the original box, paperwork and of course the module. They go for $279 plus shipping on their website. First $175 gets it (shipping included in the 48 states). I can do PayPal or will accept check (must clear bank before shipping). I am selling it because I changed vehicles and my new car does not have OnStar.
Best way to contact me is via Yahoo email (fm_miATyahooDOTcom). You can read more about the unit at there website (costartech.com/pb/products/bluestar.html) as well as on this forum (a number of people have them).
Frank in Michigan
To answer a few questions (I cannot edit the original post):
1) You do NOT need any dealer programming. It is truly plug and work (well, you do have to pair your phone).
2) I believe you can pair 4 different phones and it automatically pairs with the them once you start the car. If two paired phones are in the car, it will pair with the first one you set up, then the second, then the next one... (I have only two phones and have paired both with no issue).
3) You remove the OnStar module and insert this one. You can at any time remove the BlueStar module and reinstall the OnStar module. NO wires are cut, not noticeable damage/changes are seen
4) It works with just about every GM OnStar (and some imports) from about 2000 on. There is a way to check your car on the costartech website.
5) There is a mini USB connector that is used to do updates and to adjust special parameters. You can also make adjustments using the 3 OnStar buttons.
6) It works with OnStar regardless of type - mirror mount, roof mount, etc...
Thanks for looking! I will post once it is sold.
