Rear Door Clunk
tried a search but got back strange results. 07 GMT900 CC/SB right rear door. When driving hear a rattle. When parked I can take door handle and make the door rattle. The body lines and gaps look good, but the two rubber snubbers dont appear to touch the body. If I adjust the strike plate in, then the door wont be flush with the body. Any suggestions other than turning the stereo up louder?
I had this happen to me on my rear driver side door, turned out the dealership left an LED strip light in my door.
