Spark Plug Replacment - 07 Avalanche
Hello all,
Just wondering how hard it is to replace the spark plugs in my 07 Avalanche (5.3)? I have never really done any major engine work but looking at the engine it looks like I will be able to reach them all.
Anyway - is there anywhere I can can find info on the torque settings or is it just the normal "half' turn to tighten? Also need the gap size.
What plugs do you guys recommend?
I'll assume the truck still have the original plugs (104K Miles)... anything to watch for when removing?
Cheers
2007 Chevrolet Avalanche - 4WD | Avalanche, Escalade, Suburban, Tahoe, Yukon VIN C/K Service Manual | Document ID: 1707539
Spark Plug Replacement
Removal Procedure
Remove the spark plug wire from the spark plug.
1.1. Twist the spark plug wire boot a 1/2 turn.
1.2. Pull only on the boot in order to remove the wire from the spark plug.
Brush or using compressed air, blow away any dirt from around the spark plug.
Remove the spark plug.
If removing more than one plug, place each plug in a tray marked with the corresponding cylinder number.
Installation Procedure:
Inspect the spark plug gap. Adjust the gap as needed.
Spark Plug Gap
1.02 mm
0.040 in
Hand start the spark plug in the corresponding cylinder.
Tighten the plug to 15 N·m (11 lb ft).
Install the spark plug wire to the spark plug.
Inspect the spark plug wire for proper installation:
5.1. Push sideways on each boot in order to inspect the seating.
5.2. Reinstall any loose boot.
Removal Procedure
Spark Plug Gap
1.02 mm
0.040 in
Excellent !!
Thanks
Removal Procedure
Spark Plug Gap
1.02 mm
0.040 in
Excellent !!
Thanks
And as a seriously dumb addition (since it mentioned doing more than one) - do them one at a time (one plug, one wire), pulling all the plugs, and all the wires, and then trying to get the wires back in correct order is a PITA, unless they do something on the newer ones that I'm unfamiliar with.
If you use platinum or iridium tip plugs they are per-gapped and you should not try to adjust the gap. Do a search for spark plugs and/or look at the links below:
http://www.gm-trucks.com/forums/index.php?...=spark+plug+gap'>http://www.gm-trucks.com/forums/index.php?...=spark+plug+gap'>http://www.gm-trucks.com/forums/index.php?...=spark+plug+gap'>http://www.gm-trucks.com/forums/index.php?...=spark+plug+gap
Removal Procedure
Spark Plug Gap
1.02 mm
0.040 in
Excellent !!
Thanks
Its 1 plug 1 wire per cylinder...Its individual coil packs on all LS series engines no distributor. See pic below...
Removal Procedure
Spark Plug Gap
1.02 mm
0.040 in
Excellent !!
Thanks
Do you need to change the wires as well as the plugs? Anyone have an idea on costs for wires/plugs using GM original ?
Cheers
Cheers
Nope...use an ohm meter and check the resistance of the wires...anything over 5000ohm is toast...if you replace one replace them all...replacement set with lifetime warranty is usually around 50-60 bucks.
I used MSD wires on my 03, they were 68 bucks.
After reading what's been said above...The only thing I have to add is...Replace them with what you take out. Spark plugs that last 100k miles? Sign me up for another set. I'm the same way with their brakes...The GMT-800 brakes (not sure about the GMT-900's yet) would last for over 100k miles. That's some impressive shit right there.
Yup...I never replaced the brakes on my GMT-800
and the plugs and wires....well, ACDelco plugs or NGK....thats who makes the ACDelco ones...as for the wires...I have no idea who makes em for GM
Yeah...135-140k miles on Fred...Still on the factory pads as far as I know. And they're not even half worn. Truck stops great with zero vibration.
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
