Tweeter Replacement How To
This is my first upgrade to the audio system in my truck, slowly going to work on installing the mound of boxes of stereo gear I ordered. I decided that I would rather go with coaxial speakers than components so that left me with having to do something about the stock tweeters. The choice was either unhook them or replace them and I went with replace them. I picked the Rockford Fosgate P1T-S as they come with a crossover that had built in attenuation. Attenuation simply means reducing the output volume of the tweeter, I wanted this feature as I was going with the coaxials in the door I did not want the high end to be over powering. You can achieve this a few other ways, resistors or an Lpad but it is just easier when it is built into the crossover.
First off is removing the trim on the pillars, the drivers side you just pop off the cover and then it is one 8mm bolt, the opening for the bolt however is a little tight so you may need a smaller socket set or a nut driver to get it out. On the passenger side with the grab handle you have to remove the two covers on both ends of the handle then remove two 10mm bolts. The passenger side is harder to pull off but you can kind of grip in the hole for the handle then get at the top to pull it off. Once you have the clips released you then pull them straight up and they come off. Then you want to unhook the factory plug and take them into the house/garage to install the tweeters.
Next step is removing the tweeter assembly from the pillar trim, just press outward on the two tabs and it comes out no problem. From there you have to release the two tabs holding the tweeter to the tweeter grill. I used a flat head precision driver to do this.
Next you have to do some trimming to fit, it is very soft plastic so you can easily do this with a knife, just remember that since it is soft it is easy to make a mistake here and cut what you do not want to. On the tweeter grill you want to trim off as much of the old mounting plastic as you can, making sure to leave the two tabs to secure it to the pillar trim though. on the pillar trim itself you want to trim the two plastic tabs ever so slightly, about 2mm, so that the plastic edge on the tweeter fits in flush. You want to do this as the best way to secure them is to use a construction adhesive and apply it to the three tabs on the back of the trim piece.
I decided to leave the factory connector intact so I used butt connectors to connect that to wires going to the included crossover. The crossover has 3 setting, 0db, -2db and -4db, I went with the -4db to have them at a lower volume than the door speakers, this is the attenuation I mentioned above. To mount the crossovers I stuck them down in the space between the dash and the a pillar, they fit perfect with room around them, I used the included double sided tape to secure them.
Finally I took the emblems off the top of the crossover and stuck them on the tweeter grill, just an appearance thing but I figured if the bose guys have a logo I midas well too. The highs sound noticeably more clear and crisp with this addition, of course the door speakers still have to be swapped out to get a completely improved sound but this is a good start or addition if you already replaced your door speakers.
sweet! good writeup! i have thought about doing this as well, but here in a year my truck will be gone and in a new one so dont want to waste money :sigh:
    • I have an Autel, works great for what it is. Can't do some specific things because you need say the GM tool, VCDS for Audi/Volkswagon and others of course. But those times are few and far between for me.   The other tool I'd like to try one day is the new Topdon scan tools. Seen several video's on them and many youtube people review them.    I've never subscribed for updates or payed to do that stuff on my Autel, so I'm sure I'm missing out on some of the updates but I'm fine with that for now.
    • I am in the market for a bidirectional scan tool so was hoping someone can help point me in the right direction. There are so many options out there it is hard to narrow down which make/model to choose.   I have always done my own vehicle work so looking to maximize capability with the scanner. Ideal price is $1k or less but would be willing to exceed if it opens up significant benefits.  Currently my 24 2500 is the newest vehicle but also have a few mid to late 2010s Subarus as well.    It seems that the Autel MP900 has a decent amount of features at a reasonable price?
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
