Anybody using the 5 piece bedliner from dualliner???
https://www.dualliner.com/index.php
Pros/Cons???
I looked at it online, but it was too close the price of a spray in. The only advantage I could find was the rubber mat bottom that would keep loads from shifting. This could also be a disadvantage if you slide loads in and out of the bed. If you want a rubbery bottom for the bed you could go with an original Rhino liner, or you could drop in a rubber mat on top of any spray in. Plus if you want to go over the rail I don't think the dualliner can do that either.
If I were going this route I'd just get a cheap drop in as I could find and rubber mat, I bet it would be less expensive. Good luck with whatever you decide.
Yeah, Liners are starting to phase out. Spray in's have the market now. The good thing that a liner has though, is bed protection. Spray in's can't stop you from denting the bed with a load, like an engine say...but plastic liners do. However they shift around and scratch up the bed, debris get under them etc. I think if your going with a drop in that this would be the best one out there, as it wont shift or catch as much debris. But like Tex said, if you slide loads in and out, the non slip action can be a pain in the ass.
