07-09 Oem Navigation/dvd Unit With Disc!
I bought this navi unit like a morn thinking I could get it to work in my 2004 Silverado. I was wrong, so my loss could be your gain! It has 0 scratches or defects to the screen and is practically new! It also has DVD playback capabilities which didn't come with all OEM navi units. It will need to be brought to a dealer after install to be programmed, and from what I'm told it is not that expensive. My asking price is $425.00. I will cover the shipping costs to anywhere in the US. If you have any questions or would like pictures, feel free to contact me (860) 655-3658 or email: [email protected].
Can i get more info? P/N? what vehicle is it out of and pics?
thanks
It came out of a 2007 Silverado LTZ. It is a Denso DW468100-5174. P/N 15882766.
pics or rear connectors?
Yes, the rear connectors are in the back of the unit. Depending on your truck, you may have to buy the OnStar/Sat antenna kit as well as XM. I do have more pics but for some reason it's telling me they are too large to post? I tried shrinking them and I get the same message. Email me [email protected] and I will send you some more pics.
I am not positive, I have heard mixed things about needing or not needing a Bose system. I will tell you that it did come out of an 07 Silverado that did have the Bose in it...
If it was in a bose equipped vehicle, you will need to have a bose equipped truck, or cut and splice an amplifier in line, or else the music will be like 4 watts.
I'm very interested in this, but would like more information. when you say it has dvd playback capabilities, are you saying it will play dvd's(movies) ?
thanks
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
