I have a 2008 1500 4x4 4.3 V6 with 40000miles. Recently the ENGINE HOT A/C TURNED OFF warning pops up, but the engine isnt really hot. It seems to reset itself after a while. I though it did it more in wet weather, but today is dry (though yesterday rained). It did this yesterday. FIrst i disconnected the temp sensor on the left head, then reconnected it. It looked clean. This did nothing. Then, I disconnected the battery, and when i reconnected it 20 min later it was back to normal. I drove about 20 minutes twice today, at the end of the second trip it did it again. There was a recall to remove the insulation from the under seat computer, which i had done. It had the problem prior to this, and still does. Its probably occurred 10 times in the last 6 months, 7-8000 miles.
DO i justs need a temp sensor, or is it possible more involved?
thanks
Sean
thanks
Sean
Do you have a block heater?
no block heater...Connecticut isnt quite that cold.
it did it again. i disconnected the battery for 1 min, and that reset it
  • 5 months later...
This problem is all over the internet but I have yet to see a reasonable fix posted. I see some say to replace the thermostat, but the temperature guage drops to lowest reading instantly, which tells me that the engine temperature is not actually changing. Plus the problem can linger a few days and then the guage will instantly jump to a correct reading and all will be ok, until next time. some have said they have replaced the temperature sensor with no luck. Does anyone know the answer or can they explain how the thermostat can cause this to happen? I am thinking the computer must be involved in this somehow.
If the engine was hot 255F or higher the PCM would have a code and the SES light would have been on. I suspect a electrical problem possibly the cluster. BTW the PCM is not under the seat its in the engine compartment.
I was just going to post the same problem with my buddies 2008 Impala....probably the same issue
Here is my situation. 4.8l v6. 2008. Truck has no issues as long as the outside temp is about about 75*. Once temps go below that I have problems. I leave to go to work and truck has sat all night. Once I drive about 7 miles the temp guage goes from normal to nothing and my A/C wont work. If I disconnect the battery the guage goes back to normal and the A/C works fine until the next morning. Also if I don't disconnect the battery I can get on the highway on the way home and it will start working within 100 yards of the same place every day. I have no problems in the summer, but on the coldest days after sitting all weekend it shows engine hot. It has got to be something to do with the ambient temp.
  • 3 months later...
I have found This is a common problem. GM engineers have apparently decided that if the engine temperature is too low (example 195deg) that they will display "engine too hot turning ac off". I had the same problem and replaced the engine temperature sensor but that didn't fix the problem. I had GM replace the thermostat and that fixed the problem. It doesn't make sense to display this on an engine that is too cool, but that is how it works.
  • 8 months later...
This happened to me three times in my 2008 Silverado (4.3 V6). I took it to the dealer and they replaced the thermostat free of charge under the powertrain warranty. Aggravating, but at least it was a free fix.
  • 3 years later...
I have a 2007 Chevy Silverado, with this same issue, I have changed the thermostat twice and it still keeps happening. Last Thermostat change the error did not happen for a few months but started up again and we finally have cool weather. Stopped unplugging battery to reset and when the weather is cold in the morning the temp guage will start up on it's own again, but the warmer the day gets or the longer drive the truck it comes back on, very annoying any real answers for the fix out there.
I Have the GMC Sierra 3500 HD with a Vortec 6.0L . I've faced this problem well over a year now, and i only encounter its appearance after it rains, while in summer the engine works perfectly. i knew that the problem is back only from the temp gauge going lower to 90 degrees when its normally 100 (Celsius because I'm in Dubai) but i know the normal engine temp is 100. I've changed the thermostat earlier but the problem wasn't fixed, i cleaned out the battery wires after it then the problem was fixed for well over 9 months. And now the problem is back and its taunting me and really really pissing me off. Please HELP me because its my daily driver truck and i just wanna get over with this shit and get it fixed. One trick i keep doing when this appears is that i disconnect the Battery wires and reconnecting again then the problem is fixed for a few hours, then its back again. The temp here in Dubai is over 40 degrees Celsius and i always boil while driving, Hell i even had to do the battery trick even when i was on a date. TWICE for gods sake, she never called again....
Hi everyone,
This is to help whoever can benefit from it.
First my background. 28 years as an ASE Master, L1, CA Smog Tech, B & L Inspector. Been doing this way too long!
This same issue started six months ago on my personal truck but it was very random to say the least. The problem would always disappear by the time I got to my destination until last week. Going by the symptoms, I knew this was a electrical/electronic problem and not a mechanical (thermostat) problem.
My diagnostics lead me to the BCM. Problem is that as soon as I touched the wire harness going to the BCM the fault disappeared and has not returned. I did however unplug and inspect for signs of poor connections and broken wires at the BCM. I have seen way to many times that wires will break inside the insulation due to excessive stress caused by engineers. The harness is very tight going to the BCM connectors. I hope this helps some you and I will add more if my ghost shows up again.
Bought a 2011 Silverado a few months ago, same problem. Changed the thermostat to be certain and there was nothing wrong with it. Now I have a flashcal and I checked the engine temp when this A/C off code came up and the temp is just fine 168 at the moment (even though the needle stays at 0) No other codes or problems. Like you I suspect it's wiring or a connection. Thanks for the heads up, I'm going to see if it's around the BCM as well.
On my way to work I received the same error again. I reached my left foot up behind the dash and tapped a wiring harness and immediately the error disappeared and the gauge went back to normal. Now to figure out which one it was.
Edited by 11BSilverado
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
    • The not as clean as one would assume theme with the new engine oil, that reminds me of comments over the years with mechanics not always being so on board with filling an oil filter, not from the center anyway due to that typically being the clean side of the filter, danger of some contaminant falling into the filter if not careful but the realization now that the oil may not be as pure as one had assumed it would surely be. Yes it would be possible to fill from the small holes but that means messing with something to prop open the anti drain back valve if the filter is so equipped and not damage that valve in the process. Me, I have hardly ever prefilled an engine oil filter however I have prefilled diesel fuel filters with a filter on a fuel bulk tank and for anyone that has messed with diesel engines with filters and units that have a limited or no way of priming them, putting on a dry filter is a bad day to say the least with those crappy systems. But anyway back to not so clean engine oil, indeed perhaps its not so bad after all that I have not made a practice of prefilling oil filters.    As Grumpy Bear commented on keeping things clean, that I really have to wonder what the typical practice is at a dealer or any other shop that changes engine oil, do they make sure to wipe or wash off the oil plug and certainly if it fell into some gunk or onto a dirty floor, or that they wiped the filter mounting flange and didn't go and use some dirty rag and end up adding dirt to the inside of the head of the filter mount. Or be careless in how they stored or handled the new filter and if they were bumping into items under the vehicle with the filter opening facing up and having dirt drop right into the filter and if so right into the threaded center that is on the clean side. The top side, did they clean away the built up gunk that may be around the filler before removing the cap or to be really careful at that point that something right close to the filler hole that was hidden under the caps flange won't fall into the engine. Or did they clean the funnel or was that just laying there covered in oil from the oil change before and dust kicked up from sweeping the floor stuck to the oil and now that will go running into the next persons engine due to just not cleaning the funnel as "they won't know anyway" attitude as that young guy is more worried about taking a break so he can go outside and smoke a joint. Just random points that came to mind when I think about what some hired personnel may do that the shop foreman has no idea of or perhaps the whole attitude of some shops may be "eh ... who cares, they will never know the difference anyway".
    • $3.69 for 87 octane.   $4.24 for Diesel in town.
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
