Shackle Help
Can anyone tell me how to uninstall the factory shackles? I need to know what tools I need to do to get the job done. Also what has to come apart pix would be great too if ya got them.
Thanks.
Its pretty easy unless you have a towing package on your truck if so just remove it then install the shackles just be safe doing it aka jack stands on the frame not the rear end, the shackles are on the rear of the leaf spring here is a pic to show you what to look for just remove the two bolts and put the new shackles in
