Changed Tranny Filter
Had a heck of a time getting the pan off :jester:
I didnt know it didnt completely come off :(
Anyway, i still couldnt get to the filter with it tilted forward and had to remove one of the shifter cable bracket bolts to swing it outta the way.
After that i pulled the filter and replaced it.
I couldnt get the grommet thingy out tho, so i left the old ont on.
It was too tight and i didnt want to remove the old pan gasket, so i wiped the old one down and reused it.
Im happy i finally got everything back on with no leaks and will be changing the tranny fluid AGAIN today or tomorrow to completely flush out the old stuff.
The shifting actually feels more precise now, maybe its just me, but my tranny had 72k miles on her :flag::cheers:
I didnt know it didnt completely come off :jester:
I havent changed mine and dont plan on it for a while yet, but why wouldnt it come all the way off when you remove all the bolts?
Also I have had to reuse the grommet thing on some other trucks, no biggie!
how many miles were on the truck when you changed it?  How did the fluid look?
i havent done mine yet but according to the repair manual it says to
1. raise and support veh
2. remove the drain plug,drain fluid
3. remove heat shield next to catalytic converter
4. remove shift linkage for access to pan bolts
5. remove tranny pan bolts
6. pry pan loose with a screwdriver
7. clean gasket surface to tranny
8. clean pan with solvent and dry
9. remove filter from valve body
10.remove filter seal with a removal tool and replace with new one. ( i asked gm mechanic, you can keep old seal in).
11.clean pan gasket and magnet
12.reinstall pan
13.reinstall shift linkage, converter shield
14.lower veh
15.add approx 4qts of fluid through filler tube
16.in park, run engine at fast idle
17.move gear selector through each gear
18.check fluid level to proper level
19.check for leaks
    mark2
    mark2
  • Who's Online   6 Members, 0 Anonymous, 576 Guests (See full list)
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
    • I'm at 105,000 miles on my baby Duramax. No issues yet. I hit 31 mpg's traveling through hilly terrain to a project in Colorado. I will buy another 3.0. I'm not concerned.
    • I'm glad you have 14,000 trouble free miles. Frankly though, that's a really low bar. A bare minimum of 80,000 trouble free miles as the norm (rare exceptions always exist) across the whole model year should be a starting point. Good maintenance habits should push these past the 100,000 mile mark with only the most minor of issues. Let's hope GM truly leveled up the quality game with these new engines and exploding engines under 50,000 miles are gone.
    • This is exactly the reason our EV has consumed so much of my driving. I don't want to fire up a cold diesel or gas engine just to drive 2 miles up to the store. It's arguably terrible for an engine. If I'm not driving at least 10 miles and don't need to do truck things, the truck stays parked.   Enter the EV. It's immediately heating or cooling the cabin as needed (heat pump). An engine doesn't need to warm up or be driven gently. I can tear off in it with ZERO guilt. Move the car 1/4 mile from store to store and not think "gee, I'm short-cycling a lukewarm engine".   It doesn't idle in a drive-through. Doesn't idle at stop lights. (OK, neither would the diesel, if I let stop-start have its way, but I don't).   Even moving it out of the garage to wash it... HA! It doesn't need to be started just to move 40 feet. I have cars that I will actually put in neutral and push (no start) in/out of the garage or shop if they absolutely HAVE to be moved. My nice Camaros.
    • Some trailer plugs don't work. This one worked for me. Been using it for two years no issues. Amazon.com: Reese Trailer Plug Adapter, 7-Way Male Plug to 7-Way Female Plug, LED Lamp Out By-Pass, Plastic, Black, Each : Automotive
