Hey guys what size lift do you need to run 35" tires with 18" rims?
6" lift should be fine for 35's. Something else you need to factor in is the offset of the wheels. Don't go any higher (lower numerically) than -12mm
Sent while drinkin' a cold one...
I'm having to move up to 6 inch or more to keep mine from rubbing, right now I have to do a 12 point turn.
Haha thanks guys! Yea I'm talking to a company for tire prices and for some reason their prices for 35" tires are cheaper than tires that are 285/70/18's and I don't understand why.lol so instead of a 3 inch lift, I might go to a 6 inch instead. But I love looking at all your trucks on here! They give some good insight on what I would like for my truck :)
Just do a 6". Same price and a little bit more lift. BDS is a good lift. I have a McGaughy's lift and it is a pretty nice lift
Thank you all :) ended up going with somethin smaller in the end but I made it possible so I can go larger if I wanted to later on!
If fits in my new garage
Cant wait until the day where iI can park in a garage.lmao that probably wwon't happen for the first time until I'm +25 years old though.haha
Im 24 and its a back unit on my aunts 2.5 acre property. I moved out but not far. Baby steps.
Haha just turned 22 on the 18th, and my next baby step is moving into my parents guest house they are building on an empty lot they have. Don't mind payin rent when he wants to have a 4 car garage!
I have a 2 car, my house is a mother in law unit. Ill be in on Friday and there is a lot of work ahead of me
If it makes you feel any better none of my 3 trucks fit easily into our garage. Only one that came close was my '73 reg cab long bed (had to take hitch off and line it up a certain way). I doubt I'll ever drive a truck as small as my '73 as a daily driver again.
Mine has like a quarter inch of clearance getting into my parents garage but it lives outside which is depressing
sent from my truck in a field
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 636 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
