Nice trucks everyone. Meisterbk, I am in your neck of the woods. Luster I dig those wheels, Steve-O-08 and Bad Ass Silvy I think you guys got me beat, and LaserBlue I only look base model for a second or two... :)
LOL, you will get no argument with me on that point.
I wish I could have purchased a Duramax for the outright power, but that will have to be the next truck.
STOCK PIC THE DAYI BOUGHT IT
IMG 20130518 130811
AFTER 2.5 LEVEL KIT, REMOVE MOLDINGS
PUT BLACKED OUT Z71 DECALS
BLACK BULL BAR, BLACK BILLET BOWTIES FRONT AND REAR
BLACK XD REVOLVER 20X9 AND 35/12.50/20 NITTO MUD GRAPPLERS
K&N COLD AIR INTAKE AND REMOVE LOWER AIR DEFLECTOR
OE BED CAPS AND OE REAR WHEEL HOUSE LINERS
2013 silverado with black xd revolvers
IMG 20131221 122255
ONLY PICS I HAVE RIGHT NOW HAD THE RIMS ON ONE DAY IN THIS PIC AND HAVENT
HAD TIME TO TAKE BETTER PICS.
FUTURE PROJECT 5 OR 6 INCH LIFT AND BLACK TOOLBOX BORLA EXHAUST
AND GO RHINO WHEEL TO WHEEL STEPS
And one secret mod very few people know about
Move up a tire size or two and go with a m/t maybe nitto trail grappler or toyo open country m/t.
It has 245's right now, I was thinking 285 Mickey Thompson MTZ's
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
