Hey guys what size lift do you need to run 35" tires with 18" rims?
6" lift should be fine for 35's. Something else you need to factor in is the offset of the wheels. Don't go any higher (lower numerically) than -12mm
Sent while drinkin' a cold one...
I'm having to move up to 6 inch or more to keep mine from rubbing, right now I have to do a 12 point turn.
Haha thanks guys! Yea I'm talking to a company for tire prices and for some reason their prices for 35" tires are cheaper than tires that are 285/70/18's and I don't understand why.lol so instead of a 3 inch lift, I might go to a 6 inch instead. But I love looking at all your trucks on here! They give some good insight on what I would like for my truck :)
Just do a 6". Same price and a little bit more lift. BDS is a good lift. I have a McGaughy's lift and it is a pretty nice lift
Thank you all :) ended up going with somethin smaller in the end but I made it possible so I can go larger if I wanted to later on!
If fits in my new garage
Sent from my SM-N900V using Tapatalk
Cant wait until the day where iI can park in a garage.lmao that probably wwon't happen for the first time until I'm +25 years old though.haha
Im 24 and its a back unit on my aunts 2.5 acre property. I moved out but not far. Baby steps.
Haha just turned 22 on the 18th, and my next baby step is moving into my parents guest house they are building on an empty lot they have. Don't mind payin rent when he wants to have a 4 car garage!
I have a 2 car, my house is a mother in law unit. Ill be in on Friday and there is a lot of work ahead of me
If it makes you feel any better none of my 3 trucks fit easily into our garage. Only one that came close was my '73 reg cab long bed (had to take hitch off and line it up a certain way). I doubt I'll ever drive a truck as small as my '73 as a daily driver again.
Mine has like a quarter inch of clearance getting into my parents garage but it lives outside which is depressing
sent from my truck in a field
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
