ok... i dont know if anyone here will be able to help me or not, i have a 2010 silverado 5.3 i'd really like to get a little hotter cam for it but i cant seem to find any info on it. ive been told gm makes a performance cam for my truck which is probly the only way i would do it to keep the warranty. can anyone point me in the rite direction as to what would be good?
You put a different cam in it and they will probably void the entire drivetrain and emissions warranty. Just because GM offers a cam does not mean they will warranty it's use.
ive already been told by my gm dealer that if i got a gm cam their would be no problems with the warranty. true or not idk but thats what i was told
Like everyone else said, it most likely WILL void warranty even though it is a GM part... If you still want to throw one in, I would use a Comp rather than a GMPP cam... GMPP cams are way overpriced for what they are..Throw in a small Comp Xtreme, you will gain a ton more for less money
I would get that in writing. Are you sure they understood that you want a performance cam?? I dont know of any dealer that will honor a warranty due if you added a performance product.
yea i dont know, i know quite a few ppl at that dealer so who knows. maybe they just wouldnt "notice" if i ever needed warranty work done...... im not sure
yea i have been, im having a hard time finding cams in the gmpp catalog, well the parts manager told me my motor is an LC9 but i was also told it was an LS. but i should know for sure tomorrow hopefully
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
