Tire Size Options
Cheekster96
Howdy all. Just a quick question...I have a '04 Sierra Work Truck 4x4 with the steel wheels and 245/75/16s on it. Can I go to a larger size (265/75/16) on these rims? Getting to the point where it is time to start looking for tires (tire rack has lots of options).
Anbody have any pros and cons with going to a larger diameter tire over stock? It will be a "P" tire vs an "LT".
Thanks all.
Lee
I would not buy "P" tires for my light truck.
LT tires are meant for light trucks, towing, hauling, etc..
P tires are made for passenger cars.
245/75-16 = 30.46'' Diameter, 9.64'' tread width
265/75-16 = 31.64'' Diameter, 10.43'' tread width.
The wider tire will probably cause lower gas mileage because there is more friction to the road as well as the tire itself will be heavier.
You might have some rubbing issues too, I would go as far to say as you would have rubbing on hard turns.
I would not put a P tire on the truck, especially since it is a work truck. One other size you may consider if they offer it in your specific model is 265/70-16. This is what I have on my truck and it has zero rub, fits on the rim, as well as the overall circumfrance of the tire is very very close to the original tire. This means that your speedometer will be off by next to nothing.
If your truck is a half ton; listen up.
P-series tires are not just for passenger cars, 1500 series trucks come FROM THE GM FACTORY with P-series tires. Unless you are constantly overloading what your truck is capable of (which is not advised to start with) then a P-series tire is fine. They cost less, and will improve your MPG's & braking distance by reducing rotating mass.
W/T is just a trim level and means nothing more than that.
If you opt for a P-series tire though, make sure you check what the max load per tire is; which is on the sidewall of the tire.
For example: My truck has a GVWR of 6400 lbs. My tires are rated at 2535 lbs per tire, which totals 10,140 lbs. If I subtract the weight of my vehicle (6400lbs), from the maximum allowed weight of the tires it leaves me with and extra 3740 lbs. Considering the manufacturer only recommends 1000 lbs as payload, I still have a gray area of 2740lbs as a safety factor. LT tires are good for heavy hauling, a towing rig, HD trucks, 2500 series, and the 3500 series.... Otherwise you are just paying for more tire than you trucks capable of handling.
My truck fit some 33's (285/75/16) before i had the leveling kit and it did fine...you'll take bump in the mpg...but it will look pretty good!
All great stuff. Thanks all! I am leaning towards going with the P type tire. I dont do alot of heavy hauling and tow a boat that weighs about 2000lbs. The most I have in the bed is some wood and my tent and the rest of the camping gear. The truck doesnt squat at all and there is no bulge in the tires when it is loaded out. It is the W/T trim set up and I dont use it as a work truck per say. Plain jane as they come, has A/C and thats about it. Not even a cassette player in the radio! I like the 4.8 V8 in it. Have gotten 19mpg on a 90 mile Turnipke commute doing 65 (still on winter gas) and last year on the same commute on summer gas, got 21 (after a good tune up). Pretty impressed with it.
Thanks again all.
Lee
    • That should answer the maximum depth difference between the stock and the PPE so its not hugely lower. As to the PML pan, they don't make any claims that it fits the L8T with the same transmission and in fact leave their information confusing, however on the surface it says "for Duramax" and so its hard to say. I know a while back and not sure which brand it was that specifically stated that the extra capacity pan that particular company made did NOT fit the gas version.
    • There are several versions of the 5100's. Some for stock height, some for leveled, some for lifted.    Side note. I finally had a chance to tow with my 30' gooseneck with about 10,000 lbs of material on it this past week. Hands down the 5100's made the trailer towing much more stable and comfortable. I even had 10 cmu blocks in the bed. What a difference over the stock shocks.
    • According to PML, the stock pan is 4.3" deep - (PML info): Dimensions: at deepest area, PML pan is 7 inches, stock pan is 4.3 inches    PPE is 5.4" so roughly 1.1" deeper than stock
    • I had not realized that PPE has come out with a version of a cast aluminum oil pan specific to being able to fit onto the 10L1000 with the L8T engine sometime this spring. I was doubting that anyone would come out with something beyond what Dorman had in more of a direct factory pan swap. I see from one comment that is on the PPE site that they found the pan to be tighter to install then the factory unit and having to flex the exhaust down to fit it. I didn't lookup any specs if they have any as per how much lower it hangs but as it holds more oil and has fins outside the pan it would no doubt hang a certain amount lower.    I looked back at the site and they do have some depth measurements to get a rough comparison to the factory pan total height or hang down if you will at the front and rear of the pan so that will give a good idea how much further down this pan would end up being for ground clearance issues.    2024-2026 GM 6.6L Gas 10L1000 Heavy-Duty Cast Transmission Pan – Pacific Performance Engineering
    • I'm in constant amazement over the number of people that do oil maintenance by how they feel, what they were told, what materials cost, what brand A claims vs brand B.     Come to think of it, this behavior isn't exclusive to oil. 🤔 They drive this way too. 😬   There is a 20 plus page thread on BITOG on Mobil 1 Advanced Clean vs Valvoline Restore and Protect it would be amusing if it were not so........humanly pitiful.   Last Sunday we were are sitting at services and listening to a speaker talk about Jesus parable of the wide and narrow gates and he said something that hadn't dawned on me but totally fit the way people in general are about just about everything. He said there are so few people on the narrow path leading to a good reward not because the the narrow gate was hidden or hard to find but because the wide gate leading to a bad end it so darn easy and uncomplicated to follow!!!
