Questions From A Rookie
I have a 2006 GMC sierra SLE 1500 ext. cab 2wd w/ stock chrome 17" rims (6lug)
1. I am putting on 285/70/17 Nitto Terra Grapplers, is a leveling kit necessary, for clearance purposes?
I know that it is necessary to make the truck ultimately level.
2. If I go with a leveling kit what brand should I be looking at?
I have heard good things about Truxxx leveling kits.
3. If I do put a leveling kit on, would I have to buy bigger shocks as compared to putting new shocks on with no suspension modifications?
Any help would be much appreciated,
Thanks & God Bless
You don't need a leveling kit. Your 06 has torsion bars and you should be able to achieve 2" of lift out of your stock keys. But remember to get an alignment after you've adjusted the ride height. If your torsion bars are "tired", you can install the re-indexed torsion keys to get the desired lift, but I wouldn't go over 2". It opens you up to more issues and a terrible ride. Also, no new shocks required.
i thought 2wd trucks had coil springs....
which means you will need a leveling kit to achieve level. pretty much any brand will work its just a coil spring spacer on your truck and newer slightly longer shocks certainly arent goin to hurt
Oops,... my bad :confused:
Missed that 2wd part...
Need a leveling kit, get a cheap one off ebay certainly dont spend over like $80 bucks and you can use your stock shocks.
Hey thanks, helps out alot to get me going in the right direction.
@ruggedlife: I do not have coil springs, i only see a shock there, can i add a coil spring or is one needed, does it help?
Has any of you fella's experienced drastic changes in mpg when going from a 265 to 285, or whatever your case?
All of you agree on a leveling kit, would Truxxx leveling kits be ok?
interesting... i thought all the 2 wheel drive trucks had coil springs, if not, then you obviously have torsion bars, just crank up the stock adjusting bolts and see how much it brings the truck up
on second thought im pretty sure all the 2wd trucks have coil springs in the front...... ive decided you're high on crack.
rugged: Maybe high, but it would have to be on LIFE. :uhoh:
But whenever I flex the wheel hard All i see is a shock, and I am not completely dumb i know what a coil spring looks like.
weird... the shock would be inside of the coil spring. anywho, look underneath behind the trans crossmember, there should be a torsion bar crossmember there, you'll see a bolt on either side goin strait up into the torsion key, if there's threads left just tighten them up and it will raise the truck
I will def. be checking on this, i know from research that only 4wd have torsion bars so i left it at that, but i will check. How much can i gain from cranking them, so then a leveling kit is not necessary?
depends on the vehicle and if they've been fooled with before, alot of people can achieve level from just the stock keys, others end up getting a set of rough country keys for fairly cheap
Dont believe they have been fooled with, its an 06 and got it back in may of 06 when it was new. I am just trying to level it out before/after i put my 285's on it.
Rugged: i have torsion bars, just checked this morning.
So i can do away with a leveling kit because i can get the same thing from cranking the torsion bars?
    RyGuy43
    RyGuy43
  • Who's Online   5 Members, 0 Anonymous, 395 Guests (See full list)
    • This is NOT impact damage nor neglect. There were previous class action lawsuits because of such paint preparation st GM manufacturing plant. Not just the Cherry Red Color. This paint is applied in three processes to obtain the desired color.  The manufacturer will cover for 36 months or 36k miles only. That rust is actually corrosion because of the paint process failure. Corrosion is covered for 100,100 miles or a certain months. However their corrosion doesn't include this type. Go figure. Clearly manufacturer knew from previous paint issues. This started 3 weeks ago out of the blue.
    • Is it time to put a piece of tape over the CEL?
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
