Brake Controller Problem
tyhuck
I recently hooked up a Prodigy P2 brake controller in my truck and I hooked up a test circuit to try it out. I used LED lights put into a scrap piece of C-perlin and wired to a 7-pin pigtail. Everything works great except the light I hooked up to the brake signal wire. I noticed that the light blinks and the box reads a short code.
Does the brake box require resistance in order to work properly?
No, I meant the a trailer needs to be plugged in for resistance inorder for the controller to work :confused:
A large bulb, such as an old headlight of fog light instead of the LED should work.
That helped. I tried two of the square taillights wired in with the LED and it worked enough for a positive test.
I would have just hooked up to the trailer, but its being borrowed right now so I had to rig up a test light. I guess they work.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 1,140 Guests (See full list)
