Spark Plugs And Wires
stock ac delco....platinums or iridiums(can't rememeber, both work well)
Yup I agree!! From personal experience the other brands that offer the platinums and stuff will cause spitting and sputtering on these vortec motors. Don't know why but they do. Just stick with AC Delco's.
Definitely stick with what the vehicle came with, in respect to copper/platinum/iridium. I'm sure you've looked through some of the other forums and have seen things like "copper is a better conductor than platinum/iridium" and so on. Don't listen to those ignorant sluts! lol
First of all, technically, all plugs are copper, as in they all have copper cores. You may hear someone say "copper electrode". That is impossible. A copper electrode would melt/erode/corrode instantaneously inside a combustion chamber. To combat this, manufacturers coat their copper cores with a nickel/chromium or similar plating. ONCE you get into that, it's reasonable to argue that platinum/iridium are in fact better conductors than nickel.
Secondly, ignition systems have changed dramatically in the last 20 years. Traditional ignition systems (points or electronic distributor sysems) push positively charged electrons through the spark plug's center electrode, which arcs to the side electrode, then ground into the engine/chassis. Engines that have coil-over-plug designs like the currently produced vortecs operate similarly.
Earlier distributorless systems, such as the ignition system found on a late 90's S-10 pickup with a 4-cyl only have 2 coils for 4 plugs. How this operates is the coil will actually pull a negetive charge through the side electrode of one plug, arc to the center electrode, pass through the wire into the coil where it will then become a positive charge and jump through the center electrode to the side electrode and back into the block. To break it down, two of the four plugs actually fire backwards!!! That's why a double platinum came factory, and is strongly recommended for replacement. If you replace them with a single platinum, the two plugs which fire conventionally will outlast the reverse fire plugs, who's side electrodes will errode very quickly in comparison.
Well... now that I've put everyone to sleep with that rant, I hope you can all say "hey, I learned something new today" lol.
  • 1 month later...
Go with E3's
I Agree but no one else will........60K miles on the E3's and never experienced any codes or misfire as others "say" will happen. I also run Magnecor wires KV85's.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
