Shifter Cable Malfunction
Yesterday I was making a delivery and went to put my truck in drive and the truck got stuck in reverse; however the column shifter would move through all the gears without pressing the brake but would not come out of neutral. After freaking out for a bit i figured it was time to get out and see what happened. Turns out all that happened was the shifter cable came off the lever at the transmission. I popped it back on and everything worked. I drove to a nearby GM dealership and asked for the retainer clip to hold the cable onto the lever. After running to two other dealerships i come to find that there is no retainer clip to hold the cable onto the lever. Im thinking about going to napa or a hardware store and finding one to put on there as the lever is already slotted for one. Is it just me and a wierd coincidence or does this seem like an oversight on GM to not include a .01cent clip on to prevent this from happening.
I think there is a clip, they probably couldn't find it in their system, probably included with a new cable assembly
just go to a part store and get whatever style/ size retainer will fit and go with it
I had this happen to me this winter while plowing with my '01 2500 HD. The lever on the trans had corroded and had worn the nylon friction fit connector on the shift cable. I had the lever replaced first but the cable would not firmly connect. I had to replace the cable as well. I was lucky. My local dealer had the parts in stock and a tech available to get me up and running to finish plowing a major snow storm. The funny thing is that the same thing happened a week later on my company Crown Vic.
  • 1 month later...
Similar sounding problem however different cause.. I have a 2000 5.3L silverado ext cab and went to throw the truck into reverse and couldnt get it out of Drive but the sifter would move up and down.
I got out and crawled under only to notice that part of the linkage (the hard rubber "connector"?) that sits in a slotted steel mount off the frame. Well this rubber piece has a crack in it and is showing separation and wasnt sitting in the mount anymore. I manged to attached a ratchet strap and pulled it tight to the mount again, which allowed me to shift through all the gears once again.
My question is do I need to buy a whole new shifter linkage assembly or can i get away with just the rubber piece. I havent been able to find any reviews or similar problems anywhere on the net.
OH my 4x4 shifter is on the floor.
  • 10 months later...
Hello.
Well my 1996 k1500 Silverdo now has about 150k on it and its falling apart. Besides crappy door handles(replaced 2x's). alternators 2x's
door hinge pins. Seat belt malfunction. window switch intermittent. Head gasket , radiator , 2 water pumps, tie rod connectors, Paint peeling. Now I have the freeze plugs leaking. The idiot location behind the tranny cost over $600 to get to.....replaced main seal while I was there The front side ones may be able to be gotten by removing motor mount? stop leak for now.... Now after that repair: THE CABLE END THAT CONNECTS TO THE TRANNY FROM SHIFT LEVER CAME OFF. I see in this post a clip is mentioned. Replacement is over $100.00 I have a rubber band on it now. Anybody find a fix for it yet without part replacement. Or a diagram of what is supposed to be there.
    250.3k
    user087
    user087
  • Who's Online   1 Member, 0 Anonymous, 890 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
