Nbs Seatbelt Panel Removal
My girlfriend got into my NBS 07 Silverado VMax LTZ and noticed the seatbelt was wet. I have water coming in from somewhere but the headliner is clean and there were some water marks between the two doors on the passenger side.
If I can figure out how to remove the plastic panel that dovers the coiled seatbelt for the front seat passenger I should be able to find out where the water is coming in from (ie the roof or from the side) Does anyone know where there may be pictures or videos on how to do this?
Thanks for any help!
