Led Bed/cargo Area Lighting...
Hello all,
Planning to do a under the rail LED bed/cargo light strip(s) install on my 2011 2500HD 6.6ft box and was hoping someone on the board would have installation tips regarding what to wire to "tap" into and also a clean finished install of how to get wires from the under-rail LED lighting to the power source.
Has anyone done one of these installs that can/would be willing to offer input?
Thanks much,
-John
Here is a link to pictures of mine. I ran the wires from each strip toward the center of the bed sides. You can run the wires down thru there, there is a gap between the inside sheet metal and the out side sheet metal. I ran the passenger side wires back to the bumper and then over to the driver side tail light. The driver side wires back to the bumper and then up to the tail light. I mounted the switch in the round hole in the driver side steak hole. I tapped into the 12V+ at the 7-pin for power. Sorry I don't have pictures of the install but I will try and help with any questions you might have.
Thanks for the info SparkySparks! Do you thing the 1/2 ton has the same box structure/seams/openings as the 3/4 ton truck? In other words, do you think I can use the same wire routing as you?
Thanks,
-John
I'm not positive but I would thing they would be the same, you can test it like I did by using an extension cord or robe or wire as long as it has some weight to it. Run the cord into the hole in the middle of the bed side and look for it to drop out under the truck.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
