Pics Of New Rims And Wheels
billyboy2
how do u like the offset on those wheels?
I love the offset..For awhile I thought it might be too much but it turns out the fit is just perfect for what I was looking for....
Looks good, but you did take quite the chance with that lift.
yaa...i can't say from experience the performance of the lift, but i'm sure NickS (amongst others) will chime in with their concerns with your RC lift. From their experience, I would never buy that lift.
here's a thread on that lift fyi
http://www.gm-trucks.com/forums/index.php?...hl=rc+3\.5
I'm one of RC's victims too. :shakehead:
  • 1 year later...
Update: it's getting close to 2 years since I installed my RC lift and to say that I had any problems with it would be a lie.....I still enjoy it and gives a great ride and would recommend it. Tires wear even, just make sure you rotate them when you should 'cause they are MT...Just my 2 cents!!
Truck looks great!
Is it possible to run the wheel/tire combo with a 2" Leveling kit?
It's almost time for new tires and I'm leaning towards a 2" Leveling kit, with 285/65 R18. The truck is an 07 NBS Crew Cab 4wd stock.
Thanks in advance.
Truck looks great!
Thanks in advance.
I don't believe so.....
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,262 Guests (See full list)
    • I have the same running boards on my truck and I do agree they are bulky. I also find myself stepping over them when getting in and out of the truck. Besides providing protection to the rocker panels, they aren't very useful.  I will be replacing them soon with the Amp Powersteps.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
