dcox27 Posted May 3, 2011 Posted May 3, 2011 Will these tires fit with just the RC level? I just did id this weekend. I had a set of these tires on my old Tahoe and really liked them and that size looks like it may be a little big but might be just right
Stevens03 Posted May 3, 2011 Posted May 3, 2011 Pushing it but it should be ok. You might get a little scrub at full lock depending on your wheel offset.
mhenshaw Posted May 3, 2011 Posted May 3, 2011 They should fit fine. Lots of guys run that size in BFG A/t. I'm running the same size just in 20s.
dcox27 Posted May 3, 2011 Author Posted May 3, 2011 Pushing it but it should be ok. You might get a little scrub at full lock depending on your wheel offset. stock wheels so no tsure about offset. I am by no means a heavy offroader. Bird hunting in the fall and winter and towing the boat the rest of the time
brad519 Posted May 3, 2011 Posted May 3, 2011 I ran BFG AT 275/70/18's on my stock wheels with a Skyjacker 2" Level and had ZERO rubbing. General and BFG sites list both tires at 33.2 tall and Generals 10.9 Wide and BFG 11 wide so they're virtually exactly the same size so You should be good to go with that set up.
sab316 Posted May 3, 2011 Posted May 3, 2011 I ran BFG AT 275/70/18's on my stock wheels with a Skyjacker 2" Level and had ZERO rubbing.General and BFG sites list both tires at 33.2 tall and Generals 10.9 Wide and BFG 11 wide so they're virtually exactly the same size so You should be good to go with that set up. Virtually the same set up but BFG's run small. You should still be fine with that set up.. If you do rub just zip-tie the fender back some
