Engine Oil Long Life Or Not ?
Must I use long "life oil" for the oil service indicator light to work properly. Or is regular semisynt/ synt 5/30w OK ?
Engine is a 5.3 -02
Olav
It doesn't matter what kind of of oil you use (conventional,synthetic,high-mileage,etc.)
What Rich said. You get regular Dyno oil out of the factory, and GM designed the OLM using regular as well.
i don't go by oil life, never have and prob never will...its peace of mind
dino oil(conventional)=3k miles
synthetic=5k miles
yes yes i know blah blah its been proven todays oils are better then yesteryears but i like to be safe then sorry..
Yes oils have gotten better but in the most part it the Emissions system and the fact that Fuel Injection does not wash down the cylinder walls with fuel thinning out the oil that has improved engine life. Engines before fuel injection were good for 100000- 150000 miles and now 300000-400000 miles is most likely. My 2000 Silverado 5.3 has 275000 and running strong.
synthetic=5k miles
If you don't believe 3000 is way too soon to be changing the oil, get a an oil analysis done and the response they come back with saying "Your kidding us, right? Changing your oil every 3000 miles!? ROFOL!! You got at least 5000-6000 more to go!" Or something like that :dunno:
Pm me with your email addy if you'd like to see a report on my Silverado, just for giggles. I plan to do another one at the next oil change, likely late this year.
I'll send it to anyone, not just OP.
Larry
i'm not going to waste my time with an oil analysis, i've been told many times i'm wasting money but peace of mind is priceless...to each their own, if you guys want to go by OLM more power to you i just don't find the need to wait for a formula to tell me my oil is spent, far too many variables that the formula could be forgetting let alone factor in the filter it dosen't keep track of
As you said, to each his own, but healthy, amicable discussion is cool.
My oil analysis indicates my filter was still good. Another good reason to do an analysis.
I actually find them interesting just because I'm a hybrid Analytical Chemistry-degrees gearhead/nurse. As a nurse practitioner, I find the changes in lab values more interesting than the first lab values. Thus, I look forward to another analysis on my truck's oil.
I would have loved to have been a fly on Dr. Shirley's shoulder as he formulated the algorithm.
Larry
From your own sig....
"Man fears what he does not understand"- Anton LaVey
'Nuff said
oh i understand very well how OLM works and motor oil, i just choose to go another path
Only loss will be to your wallet. :dunno:
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 429 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
