No Start
07 1500 ECRB 2WD 6.0 Went to start truck this afternoon and it would not start. When I turn key there is a loud click from under the hood. I hooked up a 200 amp battery charger to the battery and got same result. I am guessing it is the starter. If it is, is there any tricks I should know about before I crawl under there?
There is a PCM fuse that controls the starter in the under hood fuse box. There are a total of 2 PCM fuses. So check them both.
If that checks out ok, it's probably the starter solenoid. Which is located on the starter.
If you can, have somebody turn the key to start and hit the starter with a hammer. A lot of times that will make a bad solenoid kick in.
