Rich P/n Lookup Please
Rich,
I'm looking to replace the front pads on my 2008 Crew, 1500 4wd, Vmax. Can I trouble you to lookup the p/n for front brake pads?
Thanks
Chuck
Yes sir,but it will have to wait until I get back from vacation Tuesday :cool: I'm down Charlotte for the NASCAR races.
No problem,I should be able to use my VIN if need be,It will be the same.
Rich,
VIN # 2GCFK13Y781273853
Front and back pads if I could trouble you.
Thanks again.
Chuck
Chuck,
OK,here are some part numbers for you...
On the OE for the front there are two different designs...
1ST DES - W/O PAD SPREADING FINGERS ON PAD SPRING CLIPS - Part#25918341
2ND DES - WITH PAD SPREADING FINGERS ON PAD SPRING CLIPS - Part#25918342
You also have a choice of a couple less expensive AC-Delco front pads...
Durastop ceramic - Part#19157524
Advantage ceramic - Part#19285993
For the rear..
OE - Part#25949454
And again a couple less expensive AC-Delco pad choices..
Durastop ceramic - Part#19159252
Advantage ceramic - Part#19286008
Tyler,
Yeah I would say they would be similar,I haven't had any complaints from either one we've sold.
It seems the biggest difference between the two is the Durastop ones are D3EA certified,and the Advantage ones are not,however both are made with same compounds according to my AC-Delco rep.,its just the Advantage ones are not certified to keep cost down.
part# For the rear.. shoes ?
mine is front pad, and rear shoe
sorry!, putting my nose in here :thumbs:
For the OE rear shoes - part#19133372
For the Durastop shoes - part#19165999
Thank you Rich !!!
I must service my rear brake, and brake fluid flush
Rich,
Thanks very much. Your generousity is appreciated.
Tyler,
I'm taking off some Hawk ceramic pads I just put on about 3-4 months ago along with some EBC rotors in the front. I'm keeping the rotors, but those pads seem to be very dirty, contrary to their literature. My wheels turn black in short order. The rotors seem to be wearing fairly quickly too. I'm going back to factory pads as I never had any braking deficiency with stock brakes anyway.
Just factory stock. They were not bad at all on dust. Figure I'll be happier with the stock ones.
