Cooper Zeon Ltz Pics On Z71 Rims
agrats84
Does anyone have pictures or experience with the Zeon LTZ's on their stock Z71 18" rims? I am narrowing down my search and leaning towards the 275/70 because of the E rating, but am not happy that they have OWL. Can someone confirm this?
Most OWL tires only have the white letters on one side, and black letters on the other. Just turn the white side in, and you won't even notice it. :)
Yea I thought the coopers have 2 different designs on each side to let you pick what you like better (or maybe those were the nittos)?
Don't know about the Coopers, but the couple of sets of Terra Grapplers I've had were like that. No white, just raised black letters on both sides...Different on each side. Black letters on one, and raised black letters on the other.
Yes, my trail grapplers have two black wall sides with a different design on each.
@dirtfan what size of tires are those and what did you do to clear them, i am thinking about trying to fit 295 55 20 with a 2" level
You will either have to trim with only a two inch level or do what I did and went with a small body lift.
Specs: 2" RC
1.5" Zone Body Lift
285/65/18 Trail Grapplers
No rub, no trimming other than a bit on my mud flaps because they stuck out into the wheel well quite a bit.
See link: My Setup
See link 2: The Setup You Want
Specs: 2" RC
1.5" Zone Body Lift
See link: My Setup
so in the setup up i want section it says his wheels are 18 offset and i am keeping my stock 20's which i beleive are 31 offset do u think i would need a spacer at all to clear these, also how much difference is there between these 295 55 and the ones you have on your truck
stock wheels have a higher positive offset which will pull them farther into the truck, which means you will have even less chances of rubbing
    ballencd
    ballencd
  • Who's Online   1 Member, 0 Anonymous, 454 Guests (See full list)
