Crazy Noise/vibration
Foxracer
i have a 2006 single cab chevy 4x2 every ones in a while i have a strange noise that sounds like something is vibrateing under the truck. the local dealer says its normal.. i know its not any ideas?
Might wanna give more details. does it happen at a certain speed, on acceleration, decceleration, braking, hitting bumps. Getting more specific on when it occurs can isolate it a little better.
well it sometime when u are at a light and take off some times with cruise control on sometimes just sitting still... it really just depends
Check heat shields, Ive seen O2 sensor rattle too. Also if you feel it thru the steering wheel more check front end components. A worn mount or bushing can do this also. Since it sounds kinda random id just get under there and do a visual check and get my hands on things and see if I can duplicate the issue otherwise when it happens if possible try to check it out then.
    250.3k
    joshua1221
    joshua1221
  • Who's Online   5 Members, 0 Anonymous, 497 Guests (See full list)
