High Idle When Warm
botomgun
Hi,All...
My truck has recently started to idle high (1200-1700 RPM) following a long run on the highway or after towing our 8K lb travel trailer. Sometimes the idle will hunt between 900 and 1200 RPM, and sometimes it will just stay at 1500 upon startup at which point it may or may not kick back down to normal. It doesn't seem that temperature is a factor as it will do this at 70 degrees outside temperature and also when the engine is at normal operating temperature. After a few days it seems as though the ECM resets itself and the idle returns to a normal RPM. No codes or messages are being displayed (other than I am due for an oil change).
While I am sure this isn't enough information to diagnose the problem, I would like to know what feedback sensors are involved that could provide information to the ECM in setting the idle speed. I am planning on cleaning the MAF and intake as I have read this may help. Anything else that I should look at?
2002 2500HD
6.0L
4L80E
195K Miles
    • On the subject of OLM, Gm's OLM tool may be more "informed" than others brands. I recall OLM's in mid-2000's Chrysler products literally counting down a set number of miles. That's all the OLM appeared to be.    I would actually expect GM to be able to explain the parameters that their OLM takes into account from a high level. No, I would not expect them to disclose their software coding or data analysis around their parameters.   So we're talking about two different topics, so to continue the subject on the other one, I'd be curious to know how much "standard particulate matter" in fresh oil is able to be filtered at first start by a fresh oil filter. How much particulate matter is enough to "matter"?   I.e. how much of a "lever" do we think this equates to (variability in particulate content, in fresh oils, between different makes/brands, some which filter less, and some that filter more).   We can say that more particles = more wear = shorter engine life as a logical statement and use that data with a little marketing to scare people into selecting a more refined/filtered oil. Using a similie, is this like deciding to forego two alcoholic drinks in a lifetime because we're worried about the potential impact on lifespan? Are there numbers which translate the ISO test results into a quantifiable increase in wear for a given engine/use case?
    • I'm pretty sure it doesn't actually recalibrate the speedometer it just changes the wheel speed sensor inputs to the computer. The truck still thinks it has stock tires.
    • I apologize, I missed this post, at risk of going off CURRENT TOPIC.   I'm not saying it is BS, I'm questioning how much information is being held back. GM is NOT going to spell out exactly every parameter in the algorithm. Liability, intellectual property, etc.    I'm not naive enough to believe that it is as simple as revolutions, coolant temperature, miles, time; are you?    I don't do irrational either, and boiling the OLM down to four simple values that I could code in an afternoon (I'm not a coder) is irrational - unless it suits your agenda to ignore it.
    • Chris 21 I appreciate your constructive response. !!  😉😉😉   The 6.6 is gas.  Correct me if I’m wrong but by recalibrating the speedo you’re correcting the shift points of the transmission on these trucks.?.
    • That is a huge misconception.     Bigger does not always equal safer.  Modifying does not make it safer either, with exceptions.   Think of this.  Your truck in stock form is capable of emergency maneuvers, proper stopping distances, its handling is designed around the factory wheel/tire packages, etc.   37s and a lift?  Now you've affected your braking distances, handling and ride control.  You've raised your center of gravity higher.  Your front visibility is now obstructed more than stock, same for your rear.  Does it look cooler?  Yes.  Does it now work as good as it did from factory on road?  NO.       As for my mention of exceptions?  Say you had a sedan or crossover.  They typically come with all season tires.  If you swap out for a performance all season or a summer tire, you improve your car by lowering its stopping distance (better braking because of traction) and improve the handling (regular and emergency) of the vehicle.  That is an actually improving modification.  My old 2019 LD 1500, I ran UHP all season tires on 20in wheels in a factory offered size.  It improved all aspects of how it drove over the Duratracs it came with from the factory in the stock 18" tire.
