Tallest Tire On A Stock Ride Hight?
ajbardo
hey everyone. its about time for new tires and i want something a little bigger. the truck doesnt have a leveling kit but i want as much tire as i can get under it for right now. what is the biggest tire anyone has used without too much rub. if i can get a lk for cheap that might be a option as well.
thanks in avance, aj.
How about some more info? Rim size?
If your not going to put a leveling kit on your pretty much limited to stock size tires for the most part.
Stock tires are 265/70/17
You can fit 275/70/17
Which are 0.5" taller and 0.5" wider. Same size that stock 20s have 275/55/20
Ok what about 285/60/17? 1inch taller same width
First off I never seen a tire in that size.
Second your not reading the tire size the right way.
285= tire width in mm
60= percent of sideway to tread
17= wheel size
275/70/17 is the exact same size as 275/55/20. The width is the same and the percent goes lower as the sideway goes smaller.
275/70/17 = 275/65/18
265/70/17 = 265/65/18
285/70/17 = 285/65/18
60= percent of sidewall height to overall width of the tire at it's widest point (not the tread width)
17= wheel diameter in inches
275/70/17 = 275/65/18 = 32.2" in Diameter
265/70/17 = 265/65/18 = 31.6" in Diameter
285/70/17 = 285/65/18 = 32.8" in Diameter
A 275/55/20 tire is only 31.9" in diameter so it's a bit smaller in OD than a 275/70/17 or 275/35/18.
I added the OD (outer diameter to the above) to give more complete information. And actually the definition of the aspect ratio was not quite accurate. I've changed it and added unit of measurement to wheel size. I believe tires are the only item manufactured in any industry that mixes both inches and metric measurements.
Lou
17= wheel size
sorry i forgot how it worked. any ways. how about 275/75/17? .5 wider 1inch taller
17= wheel size
You need a leveling kit. That is a 33 and is what I run on my truck minus the 17s
This thread has some excellent info regarding tire size, thanks to Nadielite and Lowrider. Could the Mod pin this to the top of the wheels and rims forum for quick ref? May save a lot of searching for the illusive tire size!
what size rims do you have?
Stock 20s with 275/60/20 coopers
Ok but doesn't the rim size effect the tire size aswell?
I have an NBS 07 Sierra with 275/70/17 Goodyear Silent Armors on the factory rims. They are a plus 1 size and measure 32.16" tall x 10.83" wide. The drivers side front will rub just ever so slightly while backing left at full lock. I wouldn't go any taller without a leveling kit. There are very few tires that are made this size in the 17" rim.
I tried to attach a pic but it was too large... sorry I will have to figure that out.
http://www.goodyeartires.com/tire/wrangler-silentarmor/
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 862 Guests (See full list)
