Fuel Pump
On a recent trip, pulling a trailer, my fuel pump went out. Anyone else had this happen? and why does it do that dasterdly deed?
Do you runn your tank empty, or near empty.
I know the pumps don't like to be overheated.
Best to keep lots of fuel in the tank.
have run it close to empty before. Hard NOT to when you do a lot of over the road travel with that engine! I usually start looking for a gas station at 1/4 tank, but sure goes down fast when it reaches that level, and some places, like Nevada, are few and far between stations.
Ok it breaks down like this.  Unfortunately I've helped friends replace their fuel pumps.. The fuel pump has in it a plastic impeller like a boat..it uses the gas as a form of lube.. you run your truck much below a 1/4 tank your pump isn't getting the lube it wants so it starts doing damage.. GM is totally aware of the problem...
Had to have mine replaced on my 99...started making the high-pitched whistle a bit and this was a week or 2 after a filter replacement.  No problems since.
GM fuel pumps aren't the worlds greatest.  It's not uncommon on GM trucks to have to replace them.
I've replaced them in my Blazer, Bravada, Tahoe, and even my Camaro.  I'm eagerly awaiting the day I get to replace the HD's...NOT!!!
Word!  Repalced mine at about 35k miles.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 928 Guests (See full list)
