New Shocks And Now...
I swapped out the rear shocks on my wifes 07 Tahoe and now I have the above messages. I checked the lines and they look okay. I did have to push them out of the way to remove the lower bolt on the d-side shock, but nothing extreme. Anyway, I just disconnected the battery hoping it may reset. I'm a little worried because my wife is leaving this evening to head to Houston (roughly 75 miles away) for the weekend. Any ideas? Is it safe to drive? Also the ABS light came on.
if you have a code scanner you will see
you have a wheel speed sensor issue, yah you broke it :)
Is your steering wheel still centered? There is a sensor (Inside the clockspring) and if that is not picked up as you drive down the road after 2-5 miles it will disable your traction and stability control. The ABS may be disabled because you have no stability control. Its annoying but should be safe to drive until you can get an alignment done. I had the same thing happen to me when I swapped rear blocks.
I just scanned for trouble codes with my Diablo and it showed no codes. IDK what the deal is. I never had this problem with my truck.
Sounds like you disturbed a connection for one of the rear wheel speed sensors.
As long as your wife is capable of driving that vehicle without the assistance of abs, traction or stability control, it is safe to drive and the base braking/steering/suspension systems will work normally but just without the assistance of the previously listed systems.
Indeed I did. I found the issue. I had inadvertently knocked a blue plug loose on the d-side just in front of the spare. I'm assuming it was where the wheel speed senors plug in. Thanks for advice guys.
I dont understand how to align rear leaf springs in an alignment that has no adjustment capabilities? please explain.
If you change or remove the blocks you stand a good chance of not getting the housing lined up perfectly. Even though there is pin an hole that lines the housing up, there is play in them. The pin is slightly smaller than the hole it goes in to. If you get the left side pushed back, and the right sight pushed forward, the axle housing may be 1/16 of an inch off of centre line. That effectively means the housing is pointed slightly to the left. To drive the vehicle straight, you need to hold the steering wheel turned slightly to the right to make the truck drive straight. If you watch NASCAR you will see an extreme example of what I mean. Those cars when going do the straight sections of the track are dog tracking to the left. You can see the right side of the car when it is coming straight at you.
To answer your question though, you would just loosen the u-bolts and push the housing in the direction you want it to go, it is very limited, but there is some play there.
I understand your point but my dealership shows that there is no rear adjustment available. At least that is what he paper work showed. those pins are designed to maintain tolerances. Your front alignment has tolerance perimeters and might not be exactly perfect, as long as they fall within tolerance it is considered aligned, would you assume that the pin slop on the rear blocks have that tolerance accounted for?
Just saying.
Thrust angle changes made by movement of the rear axle on it's locating pins in the leaf springs/blocks while minimal, can show up during a wheel alignment. If front toe is set off the thrust angle (like it should be) the steering wheel CAN be off center if the rear axle is shifted. It won't be much but it is possible.
So the best way to install a rear block lift would be to take measurements prior to dis-assembly and make sure each side reads exact to limit the movement in the pin holes :)
Just curious.
Just curious.
Dealer is correct, there is not official adjustment for this. It is such a small amount of play that I would just either push the housing all the way back or all the way forward on both sides. We are talking about maybe an eighth of an inch in total, and I would not be surprised to see it is only a thirtysecond of an inch. As another has said, it is such a small amount it is negligible in most cases. Keep in mind that the longer the wheelbase, the more effect it has.
From my own experience doing alignments years ago, it was not all that uncommon to see vehicles with the rear end not square with the chassis. As ChevTech77 points out, a good alignment shop and tech will set front toe based on thrust angle to compensate for it. It was also not unusual to do a front end alignment after changing leaf springs, so much so that it was unusual to not have to.
  • 1 year later...
The setting that you're looking for is setback. An easy way to ckeck if anything changed in the rear axle area, while driving down the road, is to take note of your steering wheel placement before any procedures (is it low on left of steering wheel, dead nuts centered, etc.) and take note of any change afterwards, all should be exactly the same as before you did anything. The variation will be slight unless you made your own. A machine made dowel at the hidden part of the bolt will almost be a perfect fit. Just go get a thrust angle alignment and it should be in tolerance, close to zero.
    Bulldogger
    Bulldogger
  • Who's Online   4 Members, 0 Anonymous, 840 Guests (See full list)
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
    • Out and about yesterday on a long Saturday drive I passed a lot of Shell stations. My preferred, so I pay attention. Lot's of small town Illinois so not six stations in three blocks like the city.    Everyone of them over a radius of say 100 miles had regular at $4.19 but one which was the one closest to home at $4.15. However Premium pricing varied greatly between 85 cents over regular to $1.50 over. I'm not counting the price of the station with the lowest regular so the reference is the same for the remainder and all within the same brand. However the spread discrepancy holds across all brands.     @txab, any thoughts on that?
