P300 Random Misfire
I have been troubleshooting this for some time now. I have replaced plugs, wires, fuel pressure regulator (I confirmed it was bad with fuel coming out of the vacuum line), and fuel filter. I checked the coils with a spark tester and all checked good.
I just purchased an Exhaust Back Pressure gauge and am confused by the results. The right side shows 0 psi at idle and when accelerating the engine. When hooked up to the left side the gauge fluctuates from 0 to 2 psi at idle. At steady 2000 rpm the gauge fluctuates wildly from 0 to full scale. It moves so fast from 0 to full scale that you can't see hardly see the needle.
The freeze frame data is listed below.
Fuel Sys 1 Open Loop
Fuel Sys 2 Open Loop
Calculated Load 39.2%
Engine Coolant 125deg F
STFT Bank 1 -10.9%
LTFT Bank 1 -2.3%
STFT Bank 2 14.8%
LTFT Bank 2 8.5%
Intake Manifold Press 23.9 inch hg
Engine RPM 3117 rpm
Speed 45mph
Mass Air Flow Sensor 12.69 lb/min
Throttle Position 42.3%
I am guessing the left cat is clogged but why is the needle fluctuating so wildly?
Any suggestions would be GREATLY appreciated.
Judging from your data I would say the left side cat is clogged. Also I don't like the fuel trims. Left bank is running rich, probably due to cat clogged, right side running rich, not sure if that is related. I would definately look into replacing the cat and check the fuel trims again after repair.
It's a completely stock truck.
I'm going to get a new set of cats in a week (working out of state) and see what happens. I drove it today and it barely moved. I'll post the results when I replace them.
