Battery Change = No Lights On Climate Control
My wife's '03 Yukon died yesterday so I replaced the battery and all is good except that the climate controls won't light up anymore. No display on it at all. I checked the fuses, the one that said HVAC, and it was fine. I saw similar problems while searching this forum but it appeared that everyone was able to control fan speed or temp and fixed it by following some reset type of procedure. I will try this as well when I get home but mine problem appears different since the display doesn't even show up. Is the climate control module toast? The vents also blow out hot air. Thanks for any help.
Well, I thought I fixed this problem. I got the climate controls working again by disconnecting the battery and then hooking it back up and turning the key to the on position so it would go through its calibration. Everything seemed to work until yesterday when my wife told me she had trouble starting it again. This morning I went out to start it and it would turn over fine, but never catch. I have no idea what it could be but since I can't work on it at all this week and we are driving it several hours away next week for vacation I broke down and had it towed to a local repair place. This is the first real problem I have had with this SUV so I can't complain at all, it has been very reliable. Is there a part in the electrical system that will cause these symptoms or does this sound like more than one thing? I'll do a quick rundown of what happened so far.
1. Battery died while wife was cleaning it. She had the radio on but not started. I jumped it and it was fine for a week or two.
2. Battery died last week and I wasn't able to jump it. Battery was too low so I bought a new one. Figured this was the problem, weak or defective battery since it was 6 years old.
3. Wife had problems starting the car yesterday. Battery appears like it is strong since in cranks fine, just doesn't catch. She was able to start it up after trying 4 or 5 times.
4. This morning it would not start at all. It would just crank but never catch. Towed :D
Have you checked all battery cable connections including grounds and cables themselves?
There was some corrosion on the negative cable connection to the battery but I cleaned it up and the contact is good, the only worn part was the battery side connection. The positive cable and connection look like they did the first day I bought it new. I didn't trace them all the way down though since they looked good.
Well crap. Looks like it was the fuel pump. They just called me and said it had zero fuel pressure. This will set me back $967. Sounds high but I assume this one is in the tank. He is using an AC Delco unit and said it cost a little more but was worth it. I wasn't even thinking this was the problem since all of the other stuff just happened with the battery.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
