Heater Core Coupler To Hoses
It's not hard at all.
Here's the tool:
And here is the replacement part from Gates
thats exactly the part you need cuz your not alone i had to fix this same problem myself at 3 oclock in the morning 2 days ago on the way to work. you simply slide the quick disconnect into the back then slide it off and remove the hose. then set your new one on there and gently tap it a few times into place, connect the hose, and then your done. all together less than 20 bucks at oreillys for the quick disconnect and coupler
  • 1 month later...
I removed the 2 OE connectors on the heater core and grabbed the Dorman 800-409 to replace from Oreilly. The Dorman are smaller ID and do not push on easy like the OE part. And the Dorman does not have the white clips in the pic of the Gates. The Dorman looks just like the OE but very tight. Did you guys find these very difficult to push on the core?
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 579 Guests (See full list)
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
