Trans Tsb Help
For some reason my 6 speed has starting actin up the last couple weeks. Sometimes when i let off the gas it kinda shudders like a manual in the wrong gear then disengages. Also, the 2-3 shift flare is getting worse. Sometime it is so bad that it throws you forward then shifts into gear. I know there is a TSB for the flare, i just cant find it. Also, is what im describing covered under the power train warranty?
