1989 Gmc S15 Low Vacuum And Timing Mark?
1989 Gmc s15 pickup 2wd , odometer - 112000 4 cylinder 2.5 liter automatic
I checked vacuum is approx. 15 and goes little lower...
and when I start its high idle like 1050 rpm and than after a while it calms down
I tried to check timing which should 8 btdc...but I can't see timing mark
can you guys suggest me how can I find timing mark? I can see 12,8,4,0 marks but noting on pulley..
also what could be main reason for low vacuum like 15? and how to trouble shoot?
The best way is to get underneath the truck and find the timing mark on the balancer(it will be a groove in the balancer). Once you find it get a paint pen or chalk to mark it a different colour so that you can see it when you check timing. The other thing is that you have to disable the electronic advance in the distributor. There should be a wire with a single connector on it to unplug (think it is a tan wire that is normally out of the loom).
