Squishy Brakes After Replacing Rear Shoes
I replaced my front disc/pads last weekend and did the drums/shoes this weekend. I had no problems when I replaced the front brakes, drove it all week. But after replacing the rear ones, my brake pedal is squishy and heads for the floor.
I checked my rear shoes, as snakedoctor mentions here and they're fine and seem to be in adjustment:
http://www.gm-trucks.com/forums/index.php?showtopic=134344
The only thing I think of is one of the pistons on one of the slave cylinders popped off when I was putting the shoes on one side. Abit of brake fluid leaked out, maybe 1/4 to 1/3 of a cup. The reservoir on the master cylinder is still full. So, did I get air in the lines by doing this? Would this cause my soft brakes?
Thanks - Fish
Thanks - Fish
If fluid leaked out, then air probably took its place. Time to bleed.
you definitely have air in the line. Your symptoms point straight to that and the fact you had fluid come out means air went in. bleed them.
Ok thanks guys. I wanted to change out the brake fluid anyways. When bleeding the brakes, is there anything special you have to do with an ABS system?
I did a google search and found a bunch of info on brake bleeds and GM ABS. I think I'll try the pressure bleeder from Motive and poor mans cycling of the ABS module (gravel road).
Quick question - if the antilock system hasn't been activated since I got air in the lines, would there be air in the antilock module? In other words, would i have to purge the antilock module if its isolated from the rest of the system until activated.
Not likely. Chances are very good that you only need to bleed the wheel the lost the fluid, if a very small amount leaked out.
Thanks Doug - thats what I thought. I'll give it a try and see if it makes a difference. I suppose I can't make it worse.
Yup, AIR in the line. Bleed brakes.
passengers rear
drivers rear
passengers front
drivers front
Sounds like a good time to flush the old brake fluid out tooooo. As it probably was brown which means the fluid has water in it. Causing rust in the system.
Jbo
passengers rear
drivers rear
passengers front
drivers front
Jbo
Actually, it was greenish colored. Not sure if thats what it looks like new.
passengers rear
drivers rear
passengers front
drivers front
Jbo
Ya flush it..... Never seen green brake fluid......
Jbo
passengers rear
drivers rear
passengers front
drivers front
Jbo
Jbo
yup - usually clear. Gonna try this weekend with the one man bottle (no vacuum pump) method.
I picked up a BIG jug of Prestone DOT 3 just in case.
Bled the brakes this weekend and long story short, it worked! Brakes are nice and firm again.
I used this method, with some modifications:
- I had my wife pump the brakes while I held the hose on the bled screws to make sure air didn't get past the hose and screw
- I added a little grease around the bleed hose to ensure an air tight seal as well as on the bleed screw base
- while I was holding the hose on the bleed screw, I made sort of a small "J trap" to keep fluid against the screw at all times. Otherwise brake fluid just flowed down the hose, leaving air next to the bleed screw. Don't know in the end if this made any difference, but theoretically it did.
All in all, it worked great. I haven't tried the ABS out yet to see if there are any problems, but the ABS system did its checks at start up (did this twice) and the ABS light went off so good so far. I plan on taking the truck on a gravel road to trigger the ABS to see if there was any air trapped in the module. My theory is that since the air got in at the drum slave cylinder and the ABS hasn't been activated, there should be no reason for air to be in the ABS module. We'll see if the theory holds up. :)
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 705 Guests (See full list)
